How long can i keep using Visual Composer with the theme?
Okay, so you decided to migrate from Visual Composer to Tagdiv Composer. I don’t like it at all and unlike my experience with Tagdiv there are now more questions than answers. Here are a few of my questions:
– I’m perfectly satisfied with my site (lochemsnieuws.nl) as it is and i do not have the time to rebuild every single page. First question is: how long can i keep using Visual Composer? Will you stop updating the plugin? In that case i would have to buy a VC-license.
– When i ever decide to rebuild pages in Tagdiv Compoper what will happen with page links?
I could not give you exact information about what will happen in the future updates. You can keep using Visual composer for the moment. There is no rush to make the transition to the new page editor. I believe there will be a notification when Visual composer will no longer be supported, giving you enough time to make a decision. Future updates will also add new features and options only for the tagDiv composer.
In this topic Chris provides advice about how one should make the transition to the new pages, and substitute them without any losses
– https://forum.tagdiv.com/topic/warning-tdc-tagdiv-composer/
