How setup max-height for module Slide
How setup maxheigt for module slide?
http://prntscr.com/91wcmt
Kind regards
Hi john80,
It can be done with custom CSS but it will maybe create other problems along the way. It was not meant do be styled like that.
Use this custom CSS:
.td_block_slide .td_module_slide{
height:650px!important
.td_block_slide .td-theme-slider{
height:650px!important;
You can adjust the height value as you want. Add the code above in Theme panel->Custom Css area like this:
http://screencast.com/t/VrMX0AJnx
The result should see here: http://screencast.com/t/TIDW2yyKUTe
Cheers
