How to activate forms to post comments on articles and … ???
Hello.
We are trying to use the WPForo Plugin (https://wordpress.org/plugins/wpforo/) to set up a Forum on our site using the “Newspaper – The Rimont-Pro” theme (https://demo.tagdiv.com/newspaper_the_rimont_pro/).
However, we find that when we navigate to the forum page of the “WPForo” plugin installed on our “Newspaper – The Rimont-Pro” theme, the entire right side (circled in “red” on the screenshot here: https://imgur.com/a/NhiKQq6), is 100% blank and completely empty.
1 – So, how to add widgets or other interesting things on the right side (which is currently completely empty and white) of the Forum Page based on the “WPForo” Plugin ???
2 – How to activate the addition of comments by readers on each article articles on our pages in “Newspaper – The Rimont-Pro” ???
Despite having activated (by the WordPress administration panel), as you can see on the part circled “in green” on this screenshot: https://imgur.com/a/qN21L8q, it is still impossible when clicking on an article, to be able to post a comment at the end of reading the article in question as you can see by trying to read this article yourself on our site: https://ynews.info/blog/2022/03/28/how-visiting-museums-through-2020-went-is-it-safe/.
How, then, to display the comments form to allow each person wishing to comment on an article read, to comment on it ???
Thank you for answering us on each of these two very important points for our project.
Awaiting your reply.
  • This topic was modified 4 years by grezako.
1. This plugin is not tested with our theme, so we can not provide support for it, sorry.
2. You should edit an article with the TagDiv Composer, add the element called ” Single Post Comments ” and there you can find some settings too. Also, you can use the element called ” Single Post Comments Counter ” to display the number of the comments for the current post.
