how to add a post view count in page's post loop element.
Hello, support team.
I want to add a post_view_count numbers in post loop.
Is it possible by modifying codes or by tagdiv composer?
look like this
Unfortunately, there is no setting in this element for view count.
You can modify the file from td-cloud-library/modules/tdb_module_loop.php
Please note that any change you make in the theme files after update will be overwritten and you have to make the changes again. Better save the code somewhere and then apply it again after every update.
Hope that helps you!
Hi Bettina, I’ll try to tweak that file.
