How to add a space between custom ads and blocks that are on the same column?
I have a column of 3, each column contains block 14 and a custom ad on top. the first ad is spaced correctly, but the other two are touching the blocks on mobile and i would like to fix that.
how can I make this change?
here is a photo of what it looks like, the “seven times winner for best burgers” is the ad
https://www.screencast.com/t/Iv12rvaQggXf
A screenshot is not enough. Please provide a link so we can inspect the site.
http://www.itsahoustonthingnews.com
Thank you Bogdan for always being so helpful
This is because the implementation method is different for custom ads. Please use the div’s provided here: https://forum.tagdiv.com/using-other-ads-non-adsense-ads/
