How to add a widget using a script provided?
Hi there,
I simply need to add the following widget to my website: https://docs.partnerize.com/clients/transferwise/TransferWise-Calculator-Widget.pdf
I tried the custom CSS menu, I tried the “column text” but without any success so far.
Could you please teach me how to add this widget?
Thank you very much and have a nice day guys.
Your theme is amazing.
Hello !
Unfortunately this has not been tested with Newspaper Theme and it is not covered by the support team.
Thank you for your understanding !
I just need to know how I can add any widget or script to the website.
That’s quite a fair request.
Could you please talk to your dev team about it?
Thank you for your understanding Vlad.
Hello !
The best way to implement this is using a Column Text. If the code does not render there then unfortunately is something that support cannot cover because it will definetly require custom work.
Hi Vlad,
Just to make sure, when the tutorial says:
Place the following JavaScript initialization code before the closing ​</body> ​tag.
Are you sure it should be inside the column text?
Shouldn’t it be under : theme panel > custom code > Custom Javascript ?
It doesn’t really make sense to copy the script inside the column text block, no?
Could you please double check with your colleagues?
Thank you
Best regards,
The answer was very SIMPLE:
1- Copy the Script into : theme panel > custom code > Custom Javascript
2- Copy <div id=”tw-calc-widget”><!– tw calculator will be rendered here –></div> into a column text block.
That’s it.. I don’t understand why you wasn’t keen to help me. That wasn’t professional.
I am hesitating to extend support now.
Please be more helpful next time, especially if you work as a support team member.
Customers need real answers.
Kind regards.
