How to add Author Box to selective posts (not all posts!)?
1) In Theme Panel – Post Settings we can enable / disable Author Box – but I need to include it only on selective (not all) posts on my website.
2) Also where wan we change the appearance of this box (eg avatar from square to round)?
Please help.
In order to add the author box only on some posts, you’ll need to use some single posts templates from tagDiv Cloud Literary , usually these came with this element, edit the cloud and remove the author box, after that set it on the post you do not want to have the author box, do the same withe the posts you want to have the author box.
The round box for author can be achieve only on single post template from cloud, you need to edit the single post template, click on single post author box and set the radius -> http://prntscr.com/p51ea5
