how to add background color to slide post title
i want to add bgcolor to post slide title in the home page of my website http://www.cyberscylla.com . right now its transparent.what is the custom css code to change the post title text color in the slide.
Hello pritiranjan,
You can use this cutom css to change the tile color:
.td_block_slide .td-slide-meta a, .td_block_slide .td-post-date{
color: red;
Or this one for the background color:
background-color: red;
You can add a bit of transparency to the background color if you want by using this palette from mozilla: https://developer.mozilla.org/en-US/docs/Web/CSS/CSS_Colors/Color_picker_tool
Thank you for your message.
this code also adding bgcolor to author name and date also.
i only want the bgcolor for the post title.
If you want to change color only to the title without metadata, use this code instead:
.td_block_slide h3 a{
color:red!important
