How to add custom icon for icon box
Is there a way to add a custom icon to use in the “ICON BOX” of TD Composer?
Custom icons cannot be selected and displayed besides the included icons unfortunately. I believe this request is on our list, an option to upload additional icons will be considered.
If you have actual icons in the media library you could add them in a text element maybe, and create your own image box (using column texts, titles, and buttons)
https://www.screencast.com/t/ymErBIJ6
Sorry for any inconvenience.
Thank you for your response. Unfortunately I’ll just have to wait for the feature to be added as your suggestion won’t work. I need a very small compact icon box similar to the ICON BOX in TD composer.
I can get by for awhile without the custom icons but having them would really bring my site to a new level of design.
