How to add Featured products in shop page woocommerce ?
i see in demo: https://demo.tagdiv.com/newsmag/shop/
Featured products and custom text.
can you help me, im try using Edit with TD Composer but not working.
Hello Fortnite Viet Nam,
Notice that demo is available on our demos list which can be loaded from Theme panel and it’s made with Woocommerce plugin. It’s a custom-made demo and if you want to re-create it you should import it or create it with our page builder. As a hint, you should try using the Inspector Browser to check how it’s made. -> https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
You should create a new page using the TagDiv composer and Woocommerce shortcodes:
https://docs.woocommerce.com/document/woocommerce-shortcodes/
Shortcodes are implemented like so in the TagDiv composer: https://www.screencast.com/t/LFAFqmzqyfIO using a column text element.
As a note, the tag div composer can only edit pages that have been originally created with it. The shop page is created by Woocommerce so it cannot be edited. Only replaced by a new one. Please use this guide to set another page as a shop page: https://docs.woocommerce.com/document/configuring-woocommerce-settings/
Also, you can check the following topic from here -> https://forum.tagdiv.com/topic/how-to-display-products/
