First of all, make sure you have selected amp or mobile + amp in the Newspaper -> Theme panel -> Mobile theme.
Please try to add the code here: https://www.screencast.com/t/4MklEVKk3nyi
Hope that helps you!
Hi Atithya, the place indicated by Bettina it is used for analytics code, so if your code is for analytics you can set it there (you can set as many codes you want).
Now if your code need to be set between
