I am trying to add links inside the copyright text area. I want to add links to my terms and privacy pages after the copyright like this:
2016 Mysite.com. By using this site you are agreeing to the Terms of Use and Privacy Policy.
This only sort of works, sometimes I get one of the links working and not the other, sometimes it outputs a giant text string into the footer copy and sometimes it removes part of the text. I assume you did not design the copyright text input area in the sub footer settings to accept links?
I feel like I almost have it working. Is there another way I should be writing it? Do I need to edit the footer php file?
Also, how do I center the whole copyright text area. I can center align the text with css but the whole block is still way over to the left side. How do I center align the whole footer text block?
In order to have links in the copyright section, you need to make sure you have the latest version of the theme: http://screencast.com/t/cveJAIDQb and then you can use html links inside the theme panel in the copyright area.
For the second part, this is the way the containers are set-up. The theme uses a span element for the footer which affects other parts of the theme as well. You will need custom modifications in order to edit the footer copyright.
I have checked your website and saw that the links work as expected: http://screencast.com/t/VNSbtpejX0UG and http://screencast.com/t/HFLUWyA9YDs
Please let us know if you need further assistance in this matter.
I tested the copyright area again and the html does not get converted in any way. I could not recreate the issue. Please try to disable all your plugins except visual composer, clear your cache and reset cdn if you use it. There might be a plugin conflict which interferes with the copyright links. If the problem is still there afterwards, then please send us an email at contact@tagdiv.com and provide wp-admin so we can take a look at this. Please also include a link to this topic so we can identify you.
