Hi;
I need help..Please check the pictures. Post settings in wp quiz pro plugin inside… How to add?
Hello Mustafa Varol,
Unfortunately, this plugin has not been tested with our theme and we cannot say for sure if it will work as expected or not with our product, sorry! If you want to integrate this plugin into our theme you should make some deeper investigation and add/inject some custom code if you want to bring best results. So, if you want to display our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom services at the moment, sorry!
Hi;
Thanks for the answer. I’ll try to decode it with code
Good work!
