How to add mobile menu without using mobile theme plugin. Currently it takes the menu of the header and in tagdiv i’m not able to set different menu for mobile. I want different menu for web and mobile. i’m using pulses pro
Hello !
You will have to create another menu in Appearance – Menus as you can see here: https://www.screencast.com/t/U0MkDEQxk9U2
I’m not getting the menu location : https://prnt.sc/v0eqdu
if i use tag div then it takes the main header menu
The mobile menu in a pro demo can be set using tagDiv Composer -> https://i.imgur.com/iUNcnZd.png select the mobile view port and click on menu ->https://i.imgur.com/7vGS5wx.png
If you are using the mobile theme plugin, then you can set the menu from here -> https://i.imgur.com/yTICVO1.png
Let me know the results!
I followed this : https://imgur.com/7vGS5wx
But when i change here, it gets changed in the web view too and thats why i’m asking your help
I just checked this on my install and for me the header menu remains on header -> https://i.imgur.com/4sLp4y1.jpg and the one selected on mobile is only for mobile -> https://i.imgur.com/U7SdrJb.png -> https://i.imgur.com/EVAQpus.png -> https://i.imgur.com/2uxSbha.png make use that you made the settings as in my screenshots.
if there is still a problem, please provide me a link where I can inspect the menu and some screenshots with the settings.
