how to add most read section?
I removed the most read section from the right panel of the website as no filter was working with it, now how do add that section again? I imported that particular section’s template but can’t add it. please help.
You can enable it from here https://i.imgur.com/nkKTnrK.png or you can use on a page the flex block and sort it -> https://i.imgur.com/5ubE5HL.png
Hi, the shreenshot that you have shared has a lot of features which I don’t have it. I think you are too privileged. Here is how it looks like for me. https://ibb.co/2hNnwsr
To have that, you need to activate the tagDiv Standard Pack plugin, this element is implemented in this plugin.
