I would like to know how I can add a custom taxonomy to Flex Block. Can you guide me through the process or provide any resources or examples that might help?
It seems I was a bit lazy… I added the ID of the custom taxonomy to the Multiple Terms Filter option and now it works well. Is this the correct way? Thank you.
Yes, it is the correct way. You can find more details here https://forum.tagdiv.com/flex-block-settings-guide/
im facing issue with the book plugin taxonomy, any help đ
Hello @Zeeshan303,
Please provide more details about what plugin you use, what you have tried to to and what errors you have.
