1. How do I add tags and custom taxonomies to the Flex Box/Loops? I created a new taxonomy for “cities” and it doesn’t show up.
2. Undo/Redo doesn’t work when I’m in the editor.
Image of the Flex box working with category. Would like to do the same for tags or custom taxonomies. Thanks!
1. For this, you need to create a module, add the module taxonomy element, and then assign the module to the flex block and flex loop builders.
2.The option for the undo-redo is disabled for this please open a page in tagDiv Composer, then click on Manager and then on settings -> https://i.imgur.com/KuvxEl6.png enable the option and should display the arrows for undo and redo ->
https://i.imgur.com/nxnyvw1.png Check this guide https://forum.tagdiv.com/tagdiv-composer-website-manager/
And what do I do after I’ve created the module? I can’t find it in the cloud library or a place to save it anywhere
You need to set here the post type name, i.e. post_tag https://i.imgur.com/aYPfAVG.png, and it will show the tags.
You can create the modules in the tab Cloud Library -> Modules -> please check the guide https://forum.tagdiv.com/modules-builder-newspaper-theme/
