how to add widget to right ad blocks position on the front page?
We’re using your template with great success, but we need a little help. Our url is http://www.bttlobo.com
Our front page is static, and we’re using the template’s right ad blocks (5 at total) only for the front page.
On the categories pages and other pages , we’re using the widgets for the right ad blocks (also 5 at total).
The problem is that we have the Ad Injection plugin installed to rotate ads in the last right ad block (bottom), and it only works as a widget.
So we would like to ask you if there’s any way we can add it as a widget to the front page right ad block?
You can use a Widgetised sidebar element for the front page
– https://www.screencast.com/t/CogcIgW1
Using this wigetised sidebar you can select from your available sidebars, in which you can have the widgets you want to use.
Please correct me if I misunderstand.
Hi there
Sorry for the reply delay.
Yes, thank you for your help, the widgetised sidebar does what we needed on the front page
Thanks again
