It can be done by editing the theme files. You can find the code for the next and previous section here: http://screencast.com/t/DZ025UWl
You need to change the code a bit to add a < to the previous article and a > to the next.
You can use the code like this:
$buffy .= '<div class="td-post-next-prev-content"><span>' .__td('<div style="padding-right:20px; font-size:20px;"><</div>Previous article', TD_THEME_NAME) . '</span>';
http://screencast.com/t/xjlGnmvly
You can use the same method for the next article and change the < symbol.
I hope this helps
