how to allow registred users publish their post to my web
I am newbie with this theme and also wordpress!!!
Anyone can help me on how to allow registred users to publish their post directly to my website.
http://www.midronepro.com
You would need to allow people to register, then perhaps have a form on your site for them to provide you with info about themselves for making them an author; set the default “allow people to register” as subscriber; but then those folks you wish to have access, you manually change their user setting from subscriber to “author” or “contributor” depending on your needs.
See the “user roles” in the WordPress.org docs (codex). Or Google “WordPress Codex User Roles” … 🙂
Or, there are some complex plugins that allow “guest posting” and that sort of thing.
Hi Chris,
Thanks for the reply.
can you suggest a plugin to do this?
May you can help me set up this if I give you access to my site???
Maybe this will help: http://www.wpbeginner.com/wp-tutorials/how-to-allow-users-to-submit-posts-to-your-wordpress-site/
But keep in mind that guest posting plugins are not tested to work with our theme and we cannot make any recommendation.
Hi Bogdan,
Thanks for the support.
Have a nice day.
It’s not cheap, but we have here chosen to use Gravity Forms.
Chris
