This can be done similarly to how it is done for articles.
First, you need to create the single CPT template you’ll use with tagDiv Composer and tagDiv Cloud Library – https://prnt.sc/dv0qKGKTCBuf then set one as global and on CTP you want an individual template from the frontend do this, open from top bar the cloud template adn select teh one you want on that CPT (click on name to become green this means taht the template is assigned individual on that cpt – https://prnt.sc/5nMcocEvyZIx)
