All the featured images are cropped to different sizes to fit on our modules but also to fit in the post templates, please check this section and see that also for post pages(some of them) the uploaded images are cropped – http://screencast.com/t/liUzod9X
So for example if you use a small image size it will not be resized, but you can try this custom css in Theme Panel > Custom Css for default post style – http://screencast.com/t/DWb7ZEMsoOP
.td-post-template-default .td-post-featured-image img {
width: 100% !important;
Hi Alin,
I add the Css on my theme cpanel, but still don’t change anythings.
http://www.screencast.com/t/XBoMo7BX
And my site is: http://weekonweek.com/
I have inspected a few posts on your site and every image that has a big enough size is croped to the maximum of 696 width.
The code Alin provided works only on the default template. If you use other post templates it will not apply.
You can use the code without the first part so it will apply on all templates:
Let us know if it still does not work and if not please provide an example of a post and an image that does not get cropped properly and a url pointing to it.
Thank you, you can see this post:
I add these code your provider.
