How to autoplay block 16 – type Next Prev ajax
Hi support,
I need autoplay block 16 when type Next Prev ajax.
Can you help me?
Hello vietnguyen,
Do you want an automatic scrolling for Block 16 Next/Prev pagination? Provide more details if this is not what you mean, sorry!
Hi support,
I need automatic scrolling for Block 16 Nex/Prev pagination.
https://i.imgur.com/9ThmPnV.jpg
How to do it?
Hello vietnguyen,
Sorry, but the theme does not have any such an option for this functionality, unfortunately!
Hi Catalin,
I know of you not support. But can you show me how to solve this problem?
Did you have tried the Infinite load more pagination from here -> https://www.screencast.com/t/4E5UTtHY7K
I need fix one row. And auto play next post.
same situation… I need this on flex block 2… anyone?
Hi all,
Unfortunately, this option has not been implemented in our theme, sorry! This functionality should have to be custom implemented in the theme if you want to have it but for achieving this, note that you need to make some custom changed over the theme core files which are not covered by our support. This is not a simple task and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry! As a hint, note that you can use the Slider for that, like this -> https://demo.tagdiv.com/newspaper/ios-slider/ because this block has functionality for autoplay, like this -> https://www.screencast.com/t/CyZsaxAnva
We managed to get a satisfactory effect without editing the source code using js 🙂 the only thing missing is playing pagination in the loop ..
