How to change background color on mobile menu. (I’ll change green to orange)
– (Sreenshot1)
How to fix footer title on ipad. It’s not justified.
– (Screenshot2)
The background color of the mobile menu can be changed from here: http://screencast.com/t/ScSJiimKnyif or if you use the mobile theme plugin: http://screencast.com/t/xb35xNWWA8u6
The 3 sections of the footer were not designed to be identical width between them. The logo container is smaller so there will be more space for the other containers. IUf you want them justified, you can use this css code:
.td-footer-wrapper .td-pb-span3, .td-footer-wrapper .td-pb-span5, .td-footer-wrapper .td-pb-span4{
width: 33.33333333%!important;
