How to change button "read more" hover style for block 12 and preview post size?
Hello, dear support team!
I couldn’t find such option for Block 12 in the post presentations on the page https://prostobzor.com/ :
1. How to set color for hover css settings ? https://prnt.sc/ut0kee
Right now I can see only this one as default – https://prnt.sc/ut0mbr
2. I found some blocks, that it was possible to set width and height for post featured image
screen – https://prnt.sc/ut0mxf
how to set sizes for block 14 in this case?
thanks for your time ? !
  • This topic was modified 6 years by kibiribi.
What you need can be achieve using flex blocks elements, the classic blocks has only few options and these are non of them.
-> https://i.imgur.com/D3wj6Ha.png -> https://i.imgur.com/7A2KI3j.png -> https://i.imgur.com/iN637OP.png
Good day Calin!
Thanks for the quick response
I didn’t quite catch – how did you change post position by arrow like this ?
https://prnt.sc/utf9uk
I can’t find how to move image left and text to the right 🙁
ok, ok – I’ve found this option – https://prnt.sc/utfhqg
But I couldn’t find real ratio to show whole image preview -https://prnt.sc/utfkg0
  • This reply was modified 6 years by kibiribi.
When I try to save visual design – I can’t finish saving – screenshot – https://prnt.sc/utfqma
watch video – https://drive.google.com/file/d/1s39ImgW0ao8juhP5sfDR2jJEYc9jsK6w/view?usp=sharing
So if I understand correctly the changes are no saving, just make sure that these problems to not be actually caused by plugins, if I remember you had before some plugins that caused some problems.
Let me know the results!
