Hi, I’m having problem with changing default comment into fb comment. How can I do that? I can’t find any setting on the theme panel. Thanks
You need to get a plugin for Facebook comments. See the WordPress.org plugins repository for possible choices.
https://wordpress.org/plugins/search.php?q=wordpress+comments
And Google is great resource for learning to use WP:
http://www.wpbeginner.com/plugins/how-to-install-and-setup-facebook-comments-in-wordpress/
I have done implementing the fb comments but the default comments still exist. I want to replace it with facebook comments
Well, did you “disable” the comments in the WP panel ?
You also disable them in the theme panel ?
Most FB comments plugins have directions on how to do this, as far as I know.
If they still show on a post, you might need to use a plugin which completely hides the existing comments; or perhaps more simply just remove the comment block from the post template you happen to be using and then only the plugin would show there, inserted at the end of the post text area.
If you don’t know how to do that, TagDiv support can provide a pointer to do that.
Maybe this will be of help: https://forum.tagdiv.com/topic/using-facebook-comments-plugin-and-changing-the-default-location/
