I’m trying to to change my font sizes to optimize my mobile experience…how can I change the font sizes for mobile? If there is a custom css code I can use that, but I haven’t been able to change the font for mobile
If you are using the responsive version, then the only solution for Newsmag theme it is to use a custom css -> https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
As an alternative, you can use the mobile theme plugin -> https://tagdiv.com/mobile-theme-get-mobile-ready-with-newsmag-theme/ this was special made for mobile, but the only inconvenience is that for pages you need to make a new content using the mobile editor ( is is to made the mobile page faster), or you can use the responsive version -> https://i.imgur.com/nMJwG9f.png
