How To Change Pagination Text Color And Background Color For Block 7 On Siddebar
Hi Tagdiv
Currently I am facing a problem for not being able to change text color and background color for pagination on Block 7 that I installed on sidebar. Because there is no option in Composer for changing the colors.
Thank you
Please try to replace block 7 with flex block and then you can change the color with tagDiv Composer.
You can change the color for block 7 using custom code CSS.
Hi Anamaria, thanks for response.
Ok I have figured out the solution.
  • This reply was modified 5 years by Romi.
