How to combine Content and Woocommerce products
I am using your theme quite a long time. I figured out that I should integrate a Woocommerce Shop. Additionally it would be great to combine content and products like they do on stylight.com.
I tried to build with visual paper a Frontpage with product catagories but the design was horrible.
Any chance to manage that with newspaper?
Hello madox56,
Unfortunately, our theme does not have such an option for it but only if you will use a bit of code to achieve this. If you want to add some blocks as content in your Woocommerce template, you will have to use the do_shortcode method to add this before or after the woo commerce products, like this -> http://screencast.com/t/hLkiEgIy for each case.
Hope this helps!
Thanks for your message!
Hi, what I really want is to place woocommerce product between article teasers on Archive pages. How can I do this?
Hello madox56,
Unfortunately, the theme does not have any such an option for it, sorry! So, if you want to customize the Archive pages through adding some Woocommerce product, you should use the do_shoerrtcode method and the code should have to be added to archive.php core file, between the article, like this -> http://screencast.com/t/eeQycz0lC Please check carefully the archive page template and try to do it yourself because we cannot provide custom work at the moment, sorry! If you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you!
