How to control number of categories shown in theme panel categories section
In earlier versions of the newspaper theme there was a theme file to edit to increase the number of categories that could be shown in the theme panel categories section. My website has a lot (about 2000) categories. What do I need to modify in newspaper version 9.7.3 to increase the number of categories that can be shown in the newspaper theme panel’s category section?
That will require a modification in file located in the composer plugin. The default limit is set to 1000 categories, which would be considered enough for most cases. You could modify it here
– http://prntscr.com/o7rgnj
Note that the modification will be lost after a theme update, when the theme plugins are updated as well.
You should give all of the option of having more than 1000 categories. Those of us who are media/newspapers/publications require more than 1000. Please consider. Thank you!
Hi MDNM2017,
I’ve noted your suggestion and I think that this can be integrate in the future updates!
