How to conver 'SIMILAR ARTICLES' to Ajax SIMILAR ARTICLES?
Hi tagDiv,
My site running with cache system by nginx, when i add new post then old posts with ‘SIMILAR ARTICLES’ not show these new post, i think, i will convert ‘SIMILAR ARTICLES’ to ajax load ‘SIMILAR ARTICLES’, how to modify code?
Best regards,
if you are using the nginx cache, it may be possible that the request will be cached even via ajax. I would recommend that you use w3 total cache with a lower caching time like 1 hour.
Thanks,
Radu O.
Hi Radu,
I can define some zone cache for don’t cached, i have just cache with .html (url).
Best regards,
