i have uploaded header from medicine layout, did some changes in the way it looks (colors, fonts etc). However sticky menu is same as in medicine demo website.
Is there an easy way to make sure all my changes in main menu are reflected in the sticky menu so it looks exactly same and there is no change when user scrolls down?
Or do I have to make all those design changes again for the sticky menu independently?
Unfortunately, you need to make the settings independently with tagDiv Composer on the header sticky, because are two different elements.
