How to create a custom sidebar for Posts and Cateogories?
I have created a sidebar for my Pages by using the TagDiv Editor, now I would like to create the same layout for Posts and Category pages.
The problem is that I have to use Apparance -> Widgets panel to customize such sidebar and there I have not the same options.
For example I have set a category list, and I have filtered such list with TagDiv editor on pages.
How can I have filter and set the number of categories here?
Is there any way to have exactly the same customised sidebar on all pages?
Is there any theme page I could edit to apply filters?
thanks
The only one solution is to use a cloud template for this and then you can modify or apply a filter like you need.
Thanks,
I have fixed later by adding some code to functions.php to be ablet to filter categories list and by editing the search wordpress widget.
