How to create and article with tagdiv without Gutemberg ?
I installed the classic editor plugin because I don’t understand Gutemberg.
When I want to create an article I see the category “post settings”.
I don’t understand where the boxes are to type the text and edit de pictures.
Check these tutorials to understand how classic editor and Gutemberg works: https://www.youtube.com/watch?v=Qdtr-QcUVv4
You can choose which one is easier for you to understand.
I desactivated the classic editor to use gutemberg.
How can I modify the home page ? I don’t see the blocks like I would with WP Bakery.
Please use our plugin called “TagDiv Composer”. Install and activate it on your website.
For more information about how to use this plugin, you can find in our guide here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Note that you don’t can use both builders in the same time, so you need to choose between WP Bakery and TagDiv Composer.
