Hello,,,,
i’m newbie, i don’t know where to find auto scroll single post feature in the theme panel…The options are not available
I just want to make single post load more automatically without clicked by visitor
thank you in advance..
yudi budiman..
Hi yudi budiman,
If you are referring to auto Scrolling from homepage, then you can set it on pro demos using tagDiv Composer on posts loop -> https://i.imgur.com/LvY710o.png
If you are referring to infinite loading, you’ll need to edit the single post template with tagDiv Composer and disable the infinite loading.
-> https://tagdiv.com/infinite-loading-for-single-posts/ from post -> https://i.imgur.com/yIf6fA3.jpg -> https://i.imgur.com/KeclHLS.jpg -> https://i.imgur.com/4jHIHFY.png
Thank you..it was successfully done.
But i had the one problem.. When i edit all cloud template via dashboard like footer, header, or etc, it is not redirected to tagdiv composer, but redirected to clasic editor.
Can Help me to fix this problem..
if you need link my blog : yudionline
Once again.. Very thank you for Your support
Hi yudi budiman,
Now our theme is more easy to be edit using only the front end -> https://i.imgur.com/wMOGjBR.png -> https://i.imgur.com/uyNdSuo.jpg also when you want to edit a cloud template from dashboard you need to click on edit template -> https://i.imgur.com/mKNUtTr.png (footer template do not has this option).
Hope this will help you!
hi..
i forgot..i mean, the footer edit template icon is not available on the dashboard..so it’s hard to editing footer with classic editor..not only that, the frontend editor(td composer) does not appear..
This reply was modified 6 years by
yudi budiman.
Hi yudi budiman,
The thing is that cloud templates so not need to be edited with classic editor, only with tagDiv Composer, also the footer template is a special template and it can be edited only if it is assigned on some pages/templates for example, you can edit the homepage with tagDiv Composer -> https://i.imgur.com/FQx8XR2.jpg -> https://i.imgur.com/6gp0Cxp.png -> https://i.imgur.com/VUcMQVG.png
thank you, your explanation is very clear..
one more question..
I want to create a table of content..in newspaper, there is a shortcode/snipet code or anything without plugins
HI..
Newspaper is really good at mobile theme with Its loading speed., i’m very satisfied for this. however at the dekstop version, i got a lower performance.
For the moment, i use Wp Rocket..i saw many topics in the forum that wp super cache is a good solution for newspaper..
My question is : ” How with the wp fastest cache. Is it good like wp super cache..?? “
Hi..
yes thanks for your sugestion. however, i saw on wp super cache did not show minify css, html, dan JS.
are there any other additional plugins for minify features..?, so the both work well, between super cache and other plugins
thank you…
yudi budiman.
