How to create box quote or pull quote in a post?
I am trying to create a box quote or pull quote but I don’t know the steps to do it. The block style I have here for a quote is the default and large only. Can the tech support help me with this?
There are a few quote styles provided by the theme – http://prntscr.com/nre4qe
The font settings for them are in the theme panel – http://prntscr.com/nre8x2
You can also create your own styles with some CSS – https://forum.tagdiv.com/topic/how-to-create-this-type-of-block/
Hi Simion,
I am using the Gutenberg editor. And my editor can’t be switched to the classic editor. How can I apply the pull quote or box quote using the Gutenberg editor.
Thanks,
With Gutenberg you will have to use the classic element, and create the quotes there
– http://prntscr.com/nrvm0a
Gutenberg itself doesn’t have many styling options for the quotes as far as I know
– https://gogutenberg.com/blocks/quote/
Or if you don’t want Gutenberg at all, simply install the classic editor plugin
– https://wordpress.org/plugins/classic-editor/
