How to create custom editable text 'block' for posts?
How can I create custom editable text ‘block’ for posts – that I can use (several times if needed) inside the posts?
I’m looking to do the following (Bold Will be Static, Italic – I should be able to change)
—–Start—–
Overview:
editable text – editable text – editable text – editable text – editable text – editable text – editable text – editable text – editable text – editable text –
What you should know
Time: 33 Hours
Date:
77 Days
Where:
Click Here
—–end——
thanks
Date and Where should be bold above (static), but I think you will get the point :))
Hello !
That can be done by using the WordPress standar editors.
TagDiv Composer is a page builder not a post builder. The options you have are the one from wordpress or you can have a 3rd party plugin but unfortunately we have not tested any and we cannot offer support for them.
