How to create FAQ drop down box and quick answer box in article page of newspape
Hi, can someone please guide how to create a FAQ drop-down box that can be connected to Yoast Schema at the end of the article? The authors can simply put those in while putting in the article on WP.
Also, any way to create a summary or quick answer box at the beginning of the article on the article page in a newspaper? I tried finding a function in TD Composer, but could not find it.
If not, then any third-party plugins you recommend.
These things have become increasingly important.
thanks in advance.
Unless I’m misunderstanding what you want to do, Yoast itself provides a FAQ block and loads schema for it. You can simply add it in the article -> https://yoast.com/how-to-build-an-faq-page/ Maybe that’s what you’re looking for.
yes, but that does not work with classic editor.
any reccomendations for article summary or quick answer box, that appears above the article?
I don’t quite know of a plugin that provides a FAQ block that can be connected to the Yoast schema and can be used with the classic editor. The Yoast FAQ schema should be used with the Yoast FAQ block.
Since you use the classic editor you need a plugin which you can add in the content via a shortcode. What about this one https://wordpress.org/plugins/faq-schema-ultimate/ It will provide it’s own schema.
Or you can create your own schema manually and add it in the post, there’s a guide here https://www.wpbeginner.com/wp-tutorials/how-to-add-faq-schema-in-wordpress/#faqschema-jsonld But you’ll need something else for creating the block.
Maybe a plugin that does them both is better. You could try the one I suggested.
