How to customize custom blocks?
I need to display BREAKING NEWS category posts just after TRENDING NOW which includes only post title and featured image not contents (excerpt). How can I set like this https://prnt.sc/geyax8
On pages you can place any of the available page builder elements. Here you can see all the available blocks on different layouts
https://demo.tagdiv.com/newspaper/block-1/
These blocks seem similar to what you want
https://demo.tagdiv.com/newspaper/block-23/
https://demo.tagdiv.com/newspaper/block-22/
https://demo.tagdiv.com/newspaper/block-18/
The number of posts can be limited for each block, the post meta can be disabled (author name, date, comment count), the excerpt can be removed by entering the value 1 in the field of the respective module
https://www.screencast.com/t/DQxiJZNh
Thanks it worked. But I couldn’t show post title. How to show post title for block 23? https://prnt.sc/gfbgh9
The post title should be displayed on all modules. If you made modifications to the excerpt of this block, make sure you did not modify the post tile excerpt as well
https://www.screencast.com/t/xwrVKBwce
The first excerpt is for the post title length, and the second one is for the excerpt content.
Thank You. It worked.
