Hello experts, I do not want to load google fonts, it increases LCP issues on core web vitals. I want to use default fonts and give the fonts a style. How can I do that?
Here you can see when I disable google fonts the fonts are like this. (Below link)
https://imgur.com/a/VsT7gfe
With Google fonts enable, the fonts are like this. (Below Link)
https://imgur.com/a/YFbhBd6
You can see with google fonts, the fonts style looks good. How can I make this style by not using google fonts enable?
Or any other style. Without google fonts, the fonts looks pretty bad as you can see. Please help me with the issue. Thanks.
Edit that page with TagDiv Composer, click on that text and you will find out a setting like this: https://www.screencast.com/t/YHQbS3LGg
From that list you can choose which size you want there.
You have also the option to use custom fonts files: https://forum.tagdiv.com/font-customization/
I tried to do that, but I cannot do that. When I log in to my WordPress dashboard from a browser, all fonts look like
even when I deactivate google fonts from the theme panel. But when I use another browser to check, then fonts appear like this
Then again if I log in to the WP dashboard from that another browser, the website changes the fonts and it looks like this again.
Can you please help me? Regards.
When you disable the google fonts, then the font weight will no longer apply. Using the default theme fonts means that you use only 2 style or the browser default font.
My recommendation is to set your own font, you can upload it with .woff extension -> https://i.imgur.com/IUJwAi9.png this should help you!
Let me know the results!
Please note that since you are using a template that is fully editable using tagDiv Composer you cannot bulk edit the fonts. You are now able to edit each element individually: https://www.screencast.com/t/SQuu3xp4zclF
