I have to deactivate the author box, but only for some articles (not all).
Unfortunately this option is not available in the theme setting. It can only be made custom. The easiest way is to edit a post template file and remove the author box for it so any post that is set to that particular style will not get the author box. You can edit the post template files here: http://screencast.com/t/Ug4x0iXvNiA
There is another way to do it without sacrificing one post template but that will involve adding conditions to the code and specifying each post Id you want the code to affect. That is a more complicated way of doing it.
