How to delete views and comment numbers on single post
i’d like to delete the number of views and comments that appears under the main post title on the right side.
see it at the following link https://staging.israele360.com/auto-cinesi-per-lidf/
thx
You need to use TagDiv Composer to edit the single post template. Then, select the elements you want to remove and press the Delete key on your keyboard (or right-click the element and choose the Delete option).
that is what i did.
Comments icon is ok, while the views icon even if i canceled as you mentioned on TadDiv Composer, i see it still there (check https://staging.israele360.com/israele-e-giordania-progetto-congiunto/)
You need to do the same, but on the view count icon, after that save the changes and see when you are loged in, after that clear the cache.
