How to disable Review system CPT
I turned off the “Review System” switcher in post settings, but the Review CPT has not been removed. How can I disable the Review system CPT? I have attached an image for reference.
In the next update, this issue related to turning off the review from the theme panel will be fixed.
Also, if you have the shortcode for reviews on the CPT, you can edit the template and delete the shortcodes related to reviews.
