How to display small text or small paragraph in Posts Loop
Hi Newspaper,
1) I am using the posts loop to display my article 2 in a row and on my right side I add a sidebar for recent post
but my article shows only post images and titles how I will display below title small text or small paragraphs.
2) in the posts loop I want to hide this message Page 1 of 2 only shows the button
Please help on this issue.
1. You need to enable the excerpt on the posts loop -> https://i.imgur.com/xyAVdqp.png for this you need to use the tagDiv Composer, edit the page, select the posts loop and search for “excerpt”.
2. The Page 1 of 2 are part from pagination, so if you want to change the pagination, then you can do it from here -> https://i.imgur.com/zYiWvtR.png if you want to remove only that text, then please use this custom css:
.tdb_loop .page-nav .pages {
display: none;
Please set the code in the theme panel > custom code> custom css.
Thank you So Much. Do You Have a Video tutorial playlist I will learn these things.
Check our video tutorials here: https://www.youtube.com/c/tagdivThemes/videos
How this text will get visible as bold
You can find the setting in the Style tab of the element: https://prnt.sc/EoqTL8nQghxp
