I’m using Default PRO. There are many templates in use. Where can I edit the templates for Posts, Pages and other main templates if there is no link in top menu to Edit Template? I would like to modify the sidebars and footers.
Hello !
That can be done either from Cloud Library as you can see here: https://www.screencast.com/t/DY2qkQqjQ7rW or by composer as you can see here: https://www.screencast.com/t/GhPYbGFF
