How to edit META info in blocks?
1) How to edit META info location of elements (using TagDivComposer) in blocks like Block 14 or others? I want to make the same visual design for Block14 as META design (Category and Title) in “Big GRid Flex 6”.
2) How to make Scale picture effect on hover for Block14 and others? They look so bored without customization.
  • This topic was modified 7 years by Austenit.
hello,
1. Sorry but the standard blocks cannot get customization settings such as the flex blocks. Please use the flex blocks if you want more options for your blocks.
2. In our theme only big grids can get hover effects. By default, no standard block can have a hover effect. However you can try this method:
https://forum.tagdiv.com/topic/create-image-hover-effect-in-all-image-frontpage-as-our-website-punjab-section/
Hello Bogdan B.,
Thank you with the second point. Is it possible to remove dark overlay on all images in blocks? Its made by default somewhere in your theme. Your team made it with that goal for better reading with text, but its really dark overlay.
Already found by myself 🙂
.td_module_mx1 .td-module-thumb a:last-child:before {
background: linear-gradient(to bottom, rgba(0, 0, 0, 0) 0%, rgba(0, 0, 0, 0.9) 100%);
If you want to remove the dark gradient over bottom image you can use this custom css
.wpb_wrapper .td-module-thumb a:last-child:before {
background: transparent;
->https://www.screencast.com/t/OtmeKq80O8o
Hope this will help you!
