Firstly, I am not using the mobile theme. The theme is just responsive with the same looks as the desktop site. I have menu links in the desktop that exceed space, so I have to to put them in a “More” menu link. But I have vertical space on mobile, so is there a way to edit that to differentiate it from the desktop, even though it’s the same link structure? Thanks.
The same menu structure from desktop will be kept on mobile, when the mobile theme plugin is not activated. So the More menu item containing the links will be the same on desktop and mobile. The actual menu structure cannot be modified simply by displaying the page on a mobile device.
The only option to have a different menu on mobile is the mobile theme.
