How to edit sub footer info
Dear Sirs I have installed RomaniaNews prebuilt, but in the mobile version (the responsive version and not with the mobile plugin theme) I have many types of sub footer. I want to edit copyright Newspaper WordPress Theme by TagDiv (is not possible via TagDivcomposers,I also edited footer.php but nothing has changed). Thanks
  • This topic was modified 4 years by frank3011.
Please don’t edit the theme files, because problems can occur.
Please make sure you have set the footer template to global -> https://i.imgur.com/WaNMqny.png
If you have a Standard Prebuilt Website you can add the copyright to the footer in Theme Panel -> Footer -> Footer info content => https://www.screencast.com/t/1mUchAid or in sub footer settings => https://www.screencast.com/t/Rrn6KKxt or if you a Pro Prebuilt Website you can edit with tagDiv Composer => https://www.screencast.com/t/UeBGkaYuundl, go to the footer and selected the element you want to edit => https://www.screencast.com/t/3vhZ5v4k and change the description.
I am sorry, but yours information are oldest. I have tryed but nothing change
No, the information is good. Please check this video and follow the steps -> https://www.screencast.com/t/Ncph3eKX
