How to enable Custom Light Sky animation on Big grid 1?
how to enable Light Sky custom animation on Big grid 1? without changing other elements like font style, position.
In order to achieve that you need to open the page with tagDiv Composer, click on Big Grid 1 and change the style -> https://www.screencast.com/t/kbthIwsX
I don’t want to change the style , can i add light sky animation without changing the current style?
If you want only the animation here is the custom css for it
.td-grid-style-1.td-hover-1 .td-big-grid-post:hover .td-module-thumb a:last-child:after {
-webkit-transition: transform 0.7s ease 0s;
-moz-transition: transform 0.7s ease 0s;
-o-transition: transform 0.7s ease 0s;
transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, 146%, 0);
-webkit-transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, 146%, 0);
-moz-transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, 146%, 0);
-ms-transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, 146%, 0);
-o-transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, 146%, 0);
.td-grid-style-1.td-hover-1 .td-module-thumb a:last-child:after {
position: absolute;
top: 0;
left: 0;
width: 160%;
height: 100%;
background: rgba(255, 255, 255, 0.2);
content: '';
z-index: 1;
transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, -120%, 0);
-webkit-transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, -120%, 0);
-moz-transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, -120%, 0);
-ms-transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, -120%, 0);
-o-transform: scale3d(1.9, 1.4, 1) rotate3d(0, 0, 1, 45deg) translate3d(0, -120%, 0);
Just change the gig grid style from here -> https://www.screencast.com/t/VTBb2xCdEjmf with the number of style that you have set https://www.screencast.com/t/3fO8phLI3mcW
-> https://www.screencast.com/t/cQrA4zrbj33C
Set the code in Newspaper>Theme panel>Custom code> Custom css
Thanks, it worked!
