How to filter an element block by taxonomy.
I am trying to filter an element block by taxonomy, but having no success.
My objective is to create a vendor spotlight post that provides a list of related article posts that have the vendors name assigned in the taxonomy of the article. I created a taxonomy call vendors using ACF and added several vendors. I have assigned a specific vendor’s name to the taxonomy of the vendor spotlight post as well as to the related articles I am trying to display in the element block. I tried using the Category filter = taxonomy-current as well as the multiple terms filter with no success. I assume this should an easy thing to do.
You can use this option to filter a block by a taxonomy: https://i.imgur.com/q2evu55.png
The filter taxonomy-current is used on the template for taxonomies; on other templates, there are specific filter options https://forum.tagdiv.com/flex-block-settings-guide/
